twocyclemania
Thread starter- Joined
- Aug 10, 2010
- 505
My 58 Evinrude 7.5 seemed to be running a bit hot so I decided to replace the pump/impeller. When I opened it I found the pump looked good. It's a plastic pump body that had apparently been a replacement. I opted for just a new impeller (pump expensive). Put a new rubber grommet on the water tube of the pump body just for safety. Put it in the test barrel and it seemed to be producing little water out the exhaust. Motor heated up to where if you put drops on the head they sizzled off (too hot) after a few minutes. I popped the power head and broke it down. The chambers looked dry; like it wasn't getting water. I checked to see if the key at the impeller had broken (my first thought) but it was okay. It seems like it's just not pumping water though it should. I didn't replace the grommet that's up in the leg though it looks good and I doubt it's the problem. Motor has had very little use and zero corrosion (fresh water). Seems pretty simple but I can't figure why it's not getting a nice cooling flow after the new impeller. Any ideas? thanks!
