timmeraw
Thread starter- Joined
- Jun 10, 2008
- 258
Re: '60 Merc 300 Awakening - No SPARK
I am at my whit's end(especially in this 90 humid weather). I replaced the impeller yet again and bolted it back up(actually had it off and on 5 times now) and can't get anything but forward gear. There is a click when approaching Neutral but that is only the tilt lock engaging. I have tried just about every position imaginable with the lower shift linkage and still no luck. I fear I may have bent the upper shift rod when one time it was not lined up right and I drove it up into the bottom of the carb. After lowering the foot I managed to get it banged back down and appears to be turning fine with no apparent bending etc.
Is there no neutral lockout or whatever to prevent starting in gear? When I first put it back together it started in gear and when running emptied half the water out of the
large can. Maybe that has something to do with my gear issues. I was able to manually turn the lower shift rod when off and find all three gears so I figure the lower unit is ok.
Any tips would be welcomed greatly.
Thanks,
Tim
Thanks,
Tim
