- Joined
- Oct 25, 2011
- 25,292
No, that hole in the step down should get a drain tube and a plug, unless you plan to use pour in foam to fill it COMPLETELY. If you fill it, IMO, theres no where for water to go if it gets into that space, so no need for a hole.
If you dont use pour in foam (I would) then put a drain tube in and when in use, keep a drain olug in the tube. Keeps any water that splashes into boat from going INTO the hole. Pull the plug when you put the boat on the trailer, same as the transom drain plug.....
