63 18 hp over heating
bbofasho
i ran into another issue with the engine. jus got it runing since i bought it. i took it out on the lake and the thing ran great. hualed *** for like 5 mins and it locked up real quick. before it locked up it was steaming out the exhuast. and i no water was supose to come out and it was but i guess not enought. it started back up ten mins later n took it to the shore and found a screen in the inlet hole. i took the screen out an it ran great for like 30 mins then did it again. steamed like crazy and locked up. waited like ten mins and drove it back to the dock. kinda lost and need some help again. anything u cuase can tell me about this issue would be awsome. and pls dont tell me to go look at other forums cuase i do that daily. thanks guys.
bktheking
Re: 63 18 hp over heating
Check your compression, could be a head gasket issue. Was the impeller changed, do you know the condition if it wasn't?
bbofasho
well i didnt check the compression but being that its really hard to pull and the engine runs great when its cold im guessing the compressiond good. and i changed the impeler before i took it out on the lake.
bktheking
You need to know the compression is good, overheating a motor can take out a head gasket in no time.
bbofasho
ehh not even that to be real. lol
um. so yur thinking blown head gasket?
im a mechanic at trade but on desiel and gas cars.
i have very little on 2 stroke and marine engines.
my point is, is normaly on a blown head gasket like 90% it wont run good.
bbofasho
im guessing blockage being that it sat for 10 yrs before i bought it. wich i should of told u and when i first started it tons and tons or carpender ants shot out the exhuast
D
DJ
Guest
You've still got a bunch of junk floating around in there.
bktheking
Now the whole story comes out LOL, ya wouldn't doubt if it's plugged up.
bbofasho
my next q. wat the hell do to take appart to clean? take the head off? the exhuast platec? i think thats wat its called? wat else is involve in the cooling system?
D
DJ
Guest
I would definetely do the head and exhaust cover. If you don't see anything there, off comes the powerhead. It's not that hard.
In the meantine, re drop the L/U and run a straigtened out coat hanger up the water tube from the pump to the powerhead. That requires no parts.
bbofasho
hhmmmmm god i hope theres a bunch of **** in there. it jus takes forever and a day to get parts. and oveously i got to replace the head gasket when i pull it off. sorry just a little impasint. lol and i did the coat hanger thing when i change the impeler.
