Re: 65Hp Evinrude bogging at WOT
I got fed up chasing the problem alone. I finally got into the one shop in the tristate area that will work on my old engine. They got different compression numbers than me. Cyl 1 - 40psi, Cyl 2 - 60, Cyl 3 - 60. I asked them to check the electronics at WOT for me. They refused at first saying they were convinced that it was a low compression problem. I explained to them that I was getting higher compression numbers (Cyl 1 - 120psi, Cyl 2 - 110, Cyl 3 120). I then re-explained my problem. AT WOT the #2 Cylinder is not firing(no spark). They then informed me they did not have a test tank and it would be hard for them to test spark at WOT under load. Before dropping the boat off to them I asked them if they could perform this test for me and if they could make sure the stator coil and timer base were working properly. They informed me they could. Which is why I took the boat up there. After they informed me of the compression findings I talked them into testing the electronics. They reluctantly said they would. A week and a half later they called back and said they did a spark test at WOT and spark tested fine. The shop still insisted that the problem is compression and offered to rebuild the powerhead for 1300 to 2000 depending on what it looked like when they took it apart.<br /><br />I have now had the boat back for 2 days. I have not had the time to recheck compression. It is first on my list of things to recheck. <br /><br />I am not discounting what the shop said. It very well could be compression. I could have been doing my compression tests wrong or my tester readings could be off. <br /><br />Everything in this post so far has pointed to spark and I find myself now very confused and bewildered!<br /><br />I will recheck my compression and repost. <br /><br />In the meantime does anyone have any thoughts or suggestions??
