a70eliminator
Thread starter- Joined
- Sep 9, 2007
- 3,762
Fuel leaking with a torrent, it's comong from around the shift rod access cover and wherever it can find a way out, all fuel hoses are good, it's all dry around the motor shroud below the carbs and near the fuel connecter, seems internal, would a bad fuel pump diaphragm cause this? The engine run great today idled good WOT 4900 range is 4500-5000. just noticed fuel spilling from around lower housing, only leaks while running, if the needle and seat were bad or float too high wouldn't I have running issues? I'm thinking something amuck in the fuel pump although she's pumping fuel alot of fuel, similar experiences anybody with the old 60's v4, Thanks.
