'67 Holiday 18' - Make it Usable
Berdink
After scrubbing her down, and without any buffing or waxing, I used some techniques I learned watching YouTube videos on how to match paint, and by mixing Rust-Oleum Hunter Green oil base with some yellow and red Rust-Oleum oil base, I'm getting pretty close.
I've also been watching YouTube videos for how to blend the new with the old so it isn't as noticable.
I've decided to keep the original paint and just do some touch-ups where needed.
Berdink
Everything is ready for her first trip since I bought her. Did the transom repair.
Got both motors mounted with new impellers.
Both run and shift great and pee good.
I'm excited to take it out.
classiccat
Good luck on your shakedown!
in the future when running in a bucket, make sure you have the water level a few inches above where the lower unit splits in order to make sure that the water pump is submerged. ... I'd go up to those lower mounts to be safe. It sounds like it was peeing so no-harm, no-foul this time. (y)
Berdink
Thanks for that.
Yes, the barrel was clear full. That's after I turned it off. I need to raise the barrel some. But yes, I do appreciate advice.
Berdink
yeah, looking at these pics, I can see the Suzuki doesn't have as steady of a stream as the mercury. The Suzuki needs to be deeper in water.
Berdink
It was really fun taking her out for my first time.
I didn't find any leaks. We stayed out anchored for at least 5 hours.
I did notice a weird electrical short where if you grab two different pieces of metal on the boat you get a little itchy type sting. I do plan on going through the wiring.
Another thing is there's a small vibration when cruising above a certain speed. I'm thinking maybe the propeller may need balancing - in that there is a small chunk missing from one propeller.
Otherwise, I really feel good about everything and hope to have lots of fun trips with her.
Thanks again for the helpful posts.
Watermann
Nice to see you got the old Holly out on the water. (y)
Electrical issue like you say sounds like the battery is grounded to the hull.
Berdink
Thanks,
So, I should probably create a main ground wire to the fuse block under the dash that runs back to the negative post on my battery, correct?
Watermann
Thanks,
The negative and positive primary wires should be the same gauge wire and yes the fuse block ground must be on the same battery as the positive. Otherwise it will seek ground anyway it can and may use your boat for the path. This also causes electrolysis corrosion and will eat holes in aluminum.
Berdink
Thank you!
I'll temporarily disconnect everything except the motor for now, and make sure it is directly connected to hot and ground.
For the daylight use I plan on using it for this summer, I only need the motor.
Berdink
Regarding my propeller having a chunk broken off, I'm thinking I should get a new one because if it is vibrating from being out of balance, that could be hard on the lower unit.
So, I don't care to go fast, so would a smaller prop, or less pitch be a good idea to lessen the load on the motor?
Berdink
Oops, I meant to include a picture.
classiccat
Your logic is correct; less pitch will get you out of the hole quicker at the expense of some high-end speed.
What RPM are you able to hit at wide-open throttle?
Wow... something really munched down on that prop of yours! I'd say you definitely need a new prop with that much missing. It wonder if it also spun the hub when it took that whack. I'd also put a dial indicator on that prop shaft, rotate the prop by hand to make sure it isn't bent. If you don't have one, a screw in a wood jig clamped to the vent plate would suffice.
Watermann
Propping a boat is almost a science. To give any kind of accurate advice on a prop a few things are needed. Motor Current prop pitch and diameter. WOT RPMs and speed. I know the 75 HP is new to the boat so that's up in the air I'd assume. So give what info you have and we can help you guess. :rolleyes:
Berdink
I know nothing about boats and outboards.
Thanks guys, I'll see what the local shop thinks.
I'll post back what they recommend.
Watermann
They may have some used in good shape props that you could buy at a reduced rate and return for a different one if that one doesn't work out.
My guess with a light Holly 18', a 75 HP motor that a 17p x 13-1/4"d aluminum 3 blade would hit the mark.
Most likely they'll want to sell you the most expensive prop they have and if that's the case get the recommendation and come back to our sponsor for a new prop, free shipping and you can get a 5% discount "forum5".
