Berdink
- Joined
- Mar 5, 2020
- 404
Yeah, the local shop wants $250 new and $100 to $150 used - depending on condition.They may have some used in good shape props that you could buy at a reduced rate and return for a different one if that one doesn't work out.
My guess with a light Holly 18', a 75 HP motor that a 17p x 13-1/4"d aluminum 3 blade would hit the mark.
Most likely they'll want to sell you the most expensive prop they have and if that's the case get the recommendation and come back to our sponsor for a new prop, free shipping and you can get a 5% discount "forum5".
Solas Amita Aluminum Boat Propeller #4411-133-17 for Suzuki 75 HP Outboard 1983 - 1997 DT 75 - iboats.com
Fast shipping and huge savings on Solas Amita Aluminum Boat Propeller #4411-133-17 for Suzuki 75 HP Outboard 1983 - 1997 DT 75boatpropellers.iboats.com
I took the prop off today and the shaft feels nice and tight in the lower unit - no play at all.
But the prop has some play on the shaft itself - the fit is somewhat loose.
I guess I have a 13-1/2 diameter by 15 inch pitch prop. 13 spline shaft.
It says made in Japan and looks original to the motor.
My use is a fishing boat, I don't care for speed. I'm more concerned about not putting too much of a load on the old engine and being able to keep all my gear loaded up in the boat, along with the 4 of us fishing.
