I changed the title to reflect what this post is actually about.
I just figured that it would make more sense when people searched it for relevant info.
I was out on the lake a couple days ago and was cursing for about 2 min (if that) and then my motor lost power then died. I looked over everything and it all seemed ok. I started it up and it started a bit hard then ran for a second and I noticed no water was coming out the hole. I shut it down instantly. Trolled back to the landing and loaded up.
Today I got to taking apart the lower unit and it looks like the metal collar separated from the rubber fins on the impeller. The rubber part of the impeller just spins around that fin. I'm assuming that is my loss of the tell-tale stream (is that what the pee stream is actually called).
My big concern is damage to the engine itself. It wasn't running very long without water but certainly long enough to hurt it. How can I tell if I did any damage to it? I replaced the impeller at the end of last season (maybe that was a mistake, should I wait till after winter?) and everything looked ok, but now look at one of the plastic tubes that comes out of the impeller. Its all melted.
I'm considering replacing the entire water pump but I don't want to do that unless I'm some what sure the actual engine is ok. The plastic that makes up the water pump is becoming cracked and damaged so I figure I should replace it.
