68 Offshore restoration
Sharpie243
What do you mean by stops? With a laser tach, where do you check? Flywheel teeth?
I have a cheap chinese oscilloscope, never have turned it on even, but I've been thinking of using that to check the gear counter pulsars output and extrapolate rpm from frequency.
Sharpie243
I was able to get some uhmw cut for the anchor nest. The aluminum is kinda crude, I'll probably replace with a couple pieces of angle, soon. Also tested the trolling motor for the first time ever, figured I should if it's partly a backup plan of the main goes out. Hasn't been used for a long time so there was dust or corrosion on the control contacts, once worked loose it seems to work. I found a cheap laser tach with reflective tape online, when it comes I'll perform more engine testing.
SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
You should have an idle speed screw/stop to adjust your idle speed. Also, if you are Out of the Water I have found my motor to Idle higher then when in the water.
As for the tach, mine came with some reflective tape I put on top of the fly wheel.
SHSU
Sharpie243
SHSU
This year of Suzuki didn't have idle speed adjustment. I think previous years did, I don't remember the reason for it going away. Doesn't really explain one spark plug firing slower than others anyway. The cheap tach has a wire wrapped around a spark wire and senses the em field, I'm wondering if that wire length just happens to have some resonance that makes it appear slower.
Clearly it's getting spark, so I plan to just go use it on the river again and see if the motor will rev higher or not, it did before. I don't really have a need to go 35 vs 25 mph, but a little wary of something not working right on the water.
SHSU
If you have one spark that is firing slower have you checked your stator?
SHSU
Sharpie243
I've checked the ohm reading, and they were all consistent. I was in the process of making all the special tools required to pull the flywheel for visual inspection when I decided to try running it again on water.
Here's my thinking:
I have cdi ignition, it doesn't really make sense for it to fire at a different rate of a trigger coil was going out. If anything, a weak signal would seem like it should just retard the timing at the same rate. If it only occasionally missed, then I wouldn't expect a consistent rate, I would expect it all over the place. If a capacitor in the cdi box was degrading, I would expect it to simply not spark. I am no ignition expert, so maybe there is more going on than I realize, but if it runs normal on the water I'm okay chalking it up to the limitations of the measurement tool.
Sharpie243
Checked with laser tach, mid 8xx, but that lower spark plug still reads 5xx on the digital tach. Tomorrow I will try to swap coils to see if the 5xx follows the coil. I am partly wondering if there could be a weird inductance issue happening, preventing the plug from firing every time, but if that were the case I would expect the spark to be good less than half the time. Best guess right now is still some weird em field in that particular wire that is giving bad readings. I still think I won't know if anything is wrong until I check top speed on water. At least it fires up every time.
My flywheel is yellow zinc coated which was too shiny for the tach so I had to spray it flat black. I figured that spraying whole running would give the most consistent finish. Didn't think it would have enough build up to fling that much off, but gave the back of my boat a light spatter coat...
I did notice that my oil tank gauge may not be functioning correctly (on top of my battery charging circuit not fully functioning even after rectifier replacement). I'm debating doing an oil injection delete, partly so I'm not worried and partly to get rid of the oil tank to make room for a real alternator (pulley off top of flywheel). I was reading about the system, and partly talked myself out of the delete because it was such a better system of oiling then gas mix. Supposedly it will inject after the carb and the oil will stay separate better. Looking at my motor today, it looks like it is injecting into the gas line prior to carb, I'm checking if this is correct or a previous owner mod. If it is correct, I think the oil delete may happen as I see no benefit.
Also today, cut some aluminum for a better anchor nest. Broke the sharp edges, hopefully assembly will be tomorrow.
cyclops222
Why do you allow so many things to deteriorate knowingly ?Now several things make getting it right is difficult.
Sharpie243
Knowingly being the key. The oil gauge was working last year. Not sure why it isn't now, probably need to check connections, just figured that out yesterday deciding to test it. The battery charging I did replace the rectifier, but it didn't seem to help, maybe the coil is bad, but it ohm'ed out correctly (no detectable shorts to ground either) and looks like it will cost me as much as an alternator to replace. Perhaps I can rewind my own if I pull it. The ignition issue is it's own thing to test, separate from the charging circuit.
It's hard to say the cause of any of it, it's all troubleshooting, once you figure out what's wrong, then it gets replaced and the deteriorated condition no longer exists. None of it points to a single piece of equipment.
Sharpie243
Version 2 of the anchor nest was attached, it should work well for now. Pondering a version 3 that adds a hinge to the front for easier solo anchoring.
SHSU
I wish I had put on a anchor nest, but ran out of room on the bow. Now my rub rail pays the price when other people pull it in...
SHSU
Sharpie243
I wasn't even going to bother with the anchor nest, then decided that I didn't want the anchor always taking up space in the boat. But now I'm thinking about anchoring for salmon solo and don't think I'd be able to do so without the nest, at least not well.
Sharpie243
As part of last Friday's to do list, I swapped the coil and tested, today. Then the engine didn't start up. Several hours later, thinking and fidgeting with the emergency kill switch clip on the key, I started thinking how dumb it would be if I forgot to place the clip...
I forgot to place the clip, not the first time I've done that and had engine troubles.
Anyway, the weird signal followed the coil, I'll try a new coil and see what happens.
I then played with connections on the multi gauge, turns out I didn't have the grounding wire quite right.
Also mounted some trailer side guides, finally found a use for that old fence post that I knew I probably shouldn't keep around. Lined with hdpe lawn edging. I'll throw on some PVC risers with some extra lighting later, very handy for backing at night.
SHSU
I always find it more rewarding when I can do my own motor work. Glad you figured your issue. At least you know what you are looking for in the future.
As for the PVC lights, I got those and very handy when trying to figure out where my tail is. That being said, I unplug the trailer harness when I dunk the trailer.
SHSU
Sharpie243
Salmon run hasn't materialized well enough this year to bother with, so I took the kids out today. Also swapped the one weird signal coil beforehand. It mostly ran fine, hit about 32-33 mph at WOT (average of up and down stream). WOT RPMs seemed a little low at 4500, and I wasn't sure if I could hear some knock so I mostly ran at half throttle or so, I don't think I'm over propped, thinking fuel supply. One WOT run while heading back to the dock, it began to surge, I think I identified a fuel line leak, so maybe some air is getting in. Either that or the fuel picked up some gunk?
Voltmeter showed mild charging at speed, so maybe the circuit is fine, just doesn't do much at idle.
Side guides on the trailer made a world of difference, but I still will want a bow guide near the rear set of center rollers.
Sharpie243
I have (had) a disposable inline external fuel filter and the internal screen filter. I have a pump maintenance kit on order as well but figured I should make sure the filters are clean if I'm having fuel supply issues. The external filter I just removed, maybe to be replaced later but I don't know how much it actually does. I went to clean the internal filter (which had some fine particulates but mostly clear) and saw this grounding wire completely fried.
It was a replacement for a wire that had appeared to have corroded, but maybe it took overheated. The replacement was a couple wire gauges larger, and still got hot enough to melt the copper. It connects the ground wires of the charging circuit and ignition, at a solid ground point (cylinder block), to the ground wire of the wire harness that leads to the dash, also at a solid ground point (lower housing). The cylinder block is well grounded by the starter ground wire as well, and I would think it is electrically connected to the lower housing as well. So, this one has me stumped how that much energy could pass through this wire. I'll be poking around, checking for discontinuities with a multimeter, but until I figure something out, I made a tripled wire in it's place.
SHSU
Possible the corrosion created enough resistance to cause the burn. Just a thought
SHSU
Sharpie243
That was my thought on the original wire. The one in the picture that burned was its replacement, only a month or two old. The weird thing is that the smaller ground wires on either side are apparently unscathed, which makes it seem like there is somehow some (big) energy running between the lower housing and the cylinder block, but as far as I know, nothing should be connected to the lower housing aside from some ground wires. The electrical flow into the block should preferentially go through the starter ground. It's a weird condition...
Sharpie243
Did some resistance checking, over 100 ohm between block and lower housing, but didn't find any sources to send power in-between (only thing I could think of would be a frayed hyd pump wire, and those were good. Checked between the block ground and the starter ground, somewhere between 60-80 ohm. The ground wire in question is 2 or 3. It's weird that it burned and the smaller wires didn't, but maybe they are actually that much more heat resistant, or maybe there was a defect in this wire...
I decided to beef up the ground and installed a 4 gauge wire between the block ground point in question and the starter ground. Should prevent future issues.
