ERRGH, finally got done with the initial grind down on the hull and transom. Ive got some problem areas that need more attention, but shouldn't be too much more grinding before i can start failing at fiberglass installation. At any rate i can at least begin forming the transom and stringers and putting together a material list.
At this point id welcome some advice on the grind and materials.
For the grind, Im guessing the smart thing would be to grind off all the roving down to the green colored glass that is barely visible in the pics. However, i really dont want to take it down that far. from what i can gather there is the green layer which may be the original mold schedule, ie gel, glass and resin, and then the stringers, devil, and transom were tossed in. after that approximatly 2 layers of roving was haphazardly tossed in near the stringers and shot with a resin cannon. I think im going to clean the remaining cracks and any air pockets bigger than a dime and move on. Let me know if this is too hab-assed of an approach.
Second the materials. Im thinking of doing something sacriligous and using OSB. I may use a better ply for the transom, but for the stringers and deck, i feel like there is no way i can prevent water intrusion 100%. Also i plan to foam everything between the deck and the hull. Now before you go off blasting me on my material selection, ill just say that OSB is an awesome building material, stronger in in some ways than plywood and has a waterproof glue like exterior grade plywoods. It may be more of a beast to glass with than i can anticipate, but im still considering it.
I cant help it, im not an overkill kind of guy, I prefer to kill something just enough to be considered legally dead, whether or not it is in fact dead is irrelevant. I think the main problem with OSB might be glassing, also i probably wont figure out its an epic failure for the 1st 5-15 years.
