WimJall
Thread starter- Joined
- Jul 11, 2018
- 111
Long story short.. (maybe not so short i dunno yet..)
I get 1997 four winns from father inlaw. get it cleaned up, runs great and then put in water, find the transom shield is cracked ( taking in copious amounts of water)
Find new shield.. pull engine, replace replace shield.. put everything back together ( after about 4 hours of aligning engine and gimble housing up..
Engine fires and then dies right away..
Like literally turn key to crank, fire sof and dies. Doesn't stay running if you hold key to crank.. turn key off, and back to crank hits right off..
Gone over every single connection that I removed to take engine out ( there's maybe 4..) and haven't found any issues..
When removing the large engine, the sensor on back side (gimble housing) made contact when removing engine ( removed fuel pump and used intake mounted plate to reinstall)
Only damage done was scraped a tad but of electric tape on harness.
What am I missing? I cannot find a wiring diagram, or even really know where to start..any help.?.
