70hp vro evinrude need help with wiring!! HELP!!
Evan.t
Re: 70hp evinrude vro wiring hookup please help!!
boat
Home Cookin'
now get the water pump replaced.
As for PTT, on those motors they are a real pain--you have to pull the motor off to remove them. The seals never seal back, but sometimes they run all rusted. So be sure yours works first. There is a 20Amp fuse hidden in the motor that serves the PTT and the starter that you need to know about.
Evan.t
boat
Evan.t
boat
Home Cookin'
what is the PTT?? i am going to try the motor first but i has cracks in it and i figure salt water got in there and siezed it . also is the water pump hard to replace? i need to fix my gas tank aswell and change oil
power trim and tilt
Home Cookin'
i found the # on the outboard motor and it turns out to be a 1988 so i dont know were you are going with this 1986
because I had a 1988 my father bought new. I replaced it with a 70 that didn't look like the 1988 but looks just like yours. No numbers on it, not even on the freeze plug, but a mechanic who works on lots of old motors said he thought 1986, based on the changes. As I said, I wasn't certain.
If your numbers are on the motor bracket and not on the engine block, yours could be a combo, too. All I'm saying, is nothing is certain.
