starkizzle
Thread starter- Joined
- Jul 21, 2016
- 52
I have a 72 johnson hydro electric I have been getting running. Just replaced shift solenoid, neutral safety switch, diode in throttle/transmission housing, and the rectifier. I just had it running strong on muff, probably 10 minutes, running fine, going through the gears, then the buzzer starts sounding consistently. I fooled with the controls for a second to see if anything stopped it then shut it down. When I hopped off the boat I noticed the water wasnt running.. My oldest doesnt like the loud noise i guess.. I dont know how long it was off.. I let it sit for a minute, and when turned the key the buzzer started right up. I didnt try turning it over. I see from the wiring that it is the overheat alarm. What could I have ruined?
-Its been sitting now for 15-20 while I did some research and posted this, turned key, no buzzer.. Will start later, first turn on water and check stream?
