Re: 75 evinrude carb adjustment
yeah, timing would be something to check to . i would try tweaking it a little bit here and there. also, you say fuel bulb emptys quickly, i am sure you have done this but is tank vent open and not pluged, is your fuel good, no water, maybe pump a sample into a glss jar to check. i think in 1975 they still had a manual choke, you can try partial choke in water with an assittant to see if that helps accellation and lean sneeze. you can also try the old trick of bringing rpms up alittle bit and closing choke momentarly. it may be ashot in the dark but this could pull through the little speck of dirt you may have missed, good luck.......
