Myfirstboat86
- Joined
- May 31, 2012
- 13
No movement in tilt and trim system when switch is pushed up or down. Pump head is hot to the touch and cables coming from battery are hot to tocuh. When the switch is pushed I hear a click from the solenoid and after holding the switch for a few seconds I hear a gulping sound coming from pump. It has a leaking seal on top of one of the push cylinders, fluid leaking out top where rod come out. Is my pump fried? How can I fix it? Thank you!
