Yammerhead
Thread starter- Joined
- Mar 29, 2008
- 15
Had the lower unit off to fix a seal and replaced the impellar while it was apart. Now that it is back together, I noticed the tell tale only dribbles at idle (1000RPM) It has to be above 2000RPM before you get any kind of stream. Even then, it is not a real strong stream. Should it be a steady stream at 1000RPM? I'm wondering if I have to pull it apart again???
