heryrg2711
Thread starter- Joined
- Jul 22, 2011
- 84
Hey guys, after getting a new starter i started the motor turns over good, runs for couple seconds then dies, i think fuel, but not the main problem.
I think the oil pump is leaking or something. Look in the pic, oil is running from the cylinder under the fuel pump right where the metal hose comes into in. Seams like an oring is bad or similar. What is this cylinder? Oil pump? And what should i do about the leak? It runs down with a constant flow, it's not dripping it runs.
EDIT: It's the oil cooler and it leaks oil. Will try and find one somewhere, if i go to the auto strore and find cooler for the b30 volvo motor, it will work correct?
Need help asap, only have little time to work on it today.
