'77 85hp Evinrude - Whoops
CreekRunner
De-carbed engine last night on hose. Let her run 15 0r 20 minutes to burn up most of gallon of gas heavy with seafoam, sometimes rev'ed up 3/4 throttle. After I shut her down, I noticed the shaft was very hot. I could put my hand on it but barely.
Did I damage anything :eek: or is this normal when on hose?
Thanks
ezeke
Re: '77 85hp Evinrude - Whoops
You should not run any two stroke engine higher than 1500 RPM with no load; the chances of a runaway are too great.
What is the "shaft" that you refer to?
CreekRunner
The shaft from cowling down to prop.
jtexas
yup, all that hot exhaust will heat the exhaust housing up I mean HOT. Gets pretty hot during normal operation, too but it's surrounded by water.
CreekRunner
Question is, reckon I hurt anything? I sure hope not. Thanks in advance.:mad:
