fishbone77
- Joined
- Apr 12, 2011
- 304
Are you going to put anything in the box to help with drainage?
Wow FB, you are getting closer and closer to getting this cap rebuilt to better than original shape...
Nice work!
FB, Was there wood originally in place where you are putting the wood now?? If not, do you realize how much added weight you're adding to your boat?
5 gallons of epoxy will ad approx 50 lbs of weight and a sheet of 3/4" plywood another 75#. Just wanted to make you aware.![]()
Does look great, Its cool to see something new almost everyday on this build... Great job.
Hey got some questions on how you flipped the Hull I'm gonna send you a pm
Hi fishbone, I am doing the same boat as you and I noticed you have 4 stringers and I only have 2. Did you add the two outside stringers? I only have the two inside ones.
Thanks, poppop.
i have had them bust the outer nut thru, see how you have a flat plate on the inside, i use them on the outside too for the eyes and keeps them from getting breaking glass
