77 Skeeter Restoration
fishbone77
Re: 77 Skeeter Restoration
After dry-fitting, I thickened up epoxy with cabosil and fiberglass shreds to a mayonnaise consistency, and spread it on the old fiberglass before clamping it back together.
Before:
Old fiberglass and foam removed:
New plywood epoxied and clamped:
fishbone77
I've decided to abandon my old plan for built-in tackle storage and switch things up a bit... Sevanseriesta made a good point about drainage a few pages back:
Are you going to put anything in the box to help with drainage?
...and I realized that it was going to be difficult with my design to either glass the inside of the box, or to keep mold from growing in the box over the long-term, so I'm opting for an alternative:
I'm going to make 2 smaller compartments instead of the single large one, each with one of these plastic plano box organizers to hold the tackle. This should solve both my drainage problems and any worries about mold...
fishbone77
Pulled the clamps tonight - amazing how much the structure here helps keep the cap square - without it, I could see it sagging, but no more! More to come tomorrow ...
fishbone77
Got out this morning to work on the cap -
Dry-fit another piece for under the casting deck...
Then I brushed epoxy over both sides of the new piece, the underside of the casting deck, and the underside of the console...
Currently waiting for the epoxy to cure a bit, but more to come...
fishbone77
Got the vertical piece of the subdeck epoxied and clamped in place, and I also mixed some PB up and contoured the seams around the casting deck...should be ready for glass tomorrow...
Also put PB in as filler on the underside of the console...
GT1000000
Wow FB, you are getting closer and closer to getting this cap rebuilt to better than original shape...
Nice work!
fishbone77
Nice work!
Thanks GT! Exciting to be making progress:D
Woodonglass
FB, Was there wood originally in place where you are putting the wood now?? If not, do you realize how much added weight you're adding to your boat?
fishbone77
Thanks WOG,
There was not wood there before - I'm definitely going to have to be careful to not get too crazy with adding too much wood - and to keep the balance right...
Woodonglass
5 gallons of epoxy will ad approx 50 lbs of weight and a sheet of 3/4" plywood another 75#. Just wanted to make you aware.;)
sevanseriesta
Does look great, Its cool to see something new almost everyday on this build... Great job.
fishbone77
Thanks WOG,
That helps give me an idea about what I've added so far, and what I was thinking of adding! I will have to sit down tonight and plug those numbers in and calculate the actual weight for what I have planned.
fishbone77
Thanks Sevanseriesta! It's fun to be making progress - it'll be nice to get this cap fixed up and put back on the hull.
fishbone77
Got glass on the underside of the casting deck tonight - more to come on Friday:joyous:
fishbone77
A little epoxy here and there - had to go pick up some more glass today...
sevanseriesta
Hey got some questions on how you flipped the Hull I'm gonna send you a pm
poppop51
Hi fishbone, I am doing the same boat as you and I noticed you have 4 stringers and I only have 2. Did you add the two outside stringers? I only have the two inside ones.
Thanks, poppop.
fishbone77
Thanks, poppop.
Hey poppop! Yes, the smaller outer stringers were my addition. Initially I thought that if I added those, I could actually save some weight and not use foam - WRONG! :eek: I think it was Oops that had the thread about the changes made in the thickness of fiberglass used for the hulls around 1970... After 1970, the hulls were made thinner because the builders realized that the closed cell foam actually has structural significance...so, even with my "bright" ... Aka ... "I really just didn't want to spend the money" idea, I ended up using foam in the end, and had 2 unnecessary stringers.
KCKracker
Got out and installed the bow eye and transom tie-downs... got a little sloppy on the inside, but I guess nobody will see it:facepalm:
i have had them bust the outer nut thru, see how you have a flat plate on the inside, i use them on the outside too for the eyes and keeps them from getting breaking glass
