'78 Ebko Lebaron - Therapy
  • Total voters
    13
  • Poll closed .
ben2go
As long as the rest of the fuel system (lines, filters, etc.) is above the top of the tank, no anti-siphon is needed. I would not install one unless it is absolutely needed. Those little valves have left many a boat stranded.
Always carry a standard flow thru fitting,teflon tape,and a 12 adjustable wrench.I'd rather make a quick switch than to end up with a gas flooded bilge.
Trooper82
Not a happy camper....
Spent the last of my boat fund this week for 2 cans of self etching primer...
Had high hopes it was going to come out looking good...
I spent the last 3 nights sanding...by hand...the tank...
This paint sucks...not going to mention the brand name....
Would be nice if it fanned out more than 3/4" when holding the nozzle the recommended distance from the part...
Stripe city...and took both cans....when looking at their suggested coverage area thought I would end up with half a can...
can I go over this with my Oil base primer I used on the trailer?
Woodonglass
Yep, now that the SE primer is on there you can coat it with what ever you want.
Trooper82
OK, I took a green scratch pad to it, looks a little better...
Seems the last bit I sprayed was just dark and collecting on top of the other layer...maybe I did it wrong?
Thanks Wood..I will put a coat of the other primer...and might as well paint it while I am at it...
jbcurt00
Scan thru some tinny resto threads.... That's exactly what most hulls look like after SE primer;)
So, yep, shoot away.... Glad you like the results better after a bit of cutting the SE w a scotchbrite pad.....
sphelps
Tank looks good troop ! BTW I just bought a can of SEP the brand starts with the letter R .I hope it's not the wrong type.:redface:
Woodonglass
The SE primer is supposed to be a LIGHT coating so you should do a light scuff with a 3m pad before shooting it with another primer and then top coat. It IS some weird stuff. I personally like the SEM product. They have a high quality nozzle on their rattle cans.
Trooper82
Here it is after the scratch pad...before I put the oil based primer on it..
Does look a lot better...I guess it was just different than what I had expected...
I went ahead and put a coat of oil base primer on it too...will consider painting it...it is just a tank though as the wife said...
Woodonglass
Yeah, but... Since it's there...Ya gotta paint it. I KNOW!!!!
sphelps
Yep , I would paint it . Just consider it practice .. ;)
Trooper82
Speaking of practice....
Noob HVLP Painting tips 101
1. If you see paint dripping out of the nozzle...it does not necessarily mean the paint is too thin...stop painting....go look where you put the gun together from the last cleaning...there could be spare parts just lying around...like maybe a spring....DOH!
I went ahead and finished, drips and all...only a tank, right?
jbcurt00
Seems as though drips & runs is still a hanging offense in Louisiana..........
Just IMHO: Looks good from my house. It'll look great under a deck near you soon!
Trooper82
I had nowhere else to put it and get it in one shot :)
sphelps
Don't feel bad about the spring Troop . The first time I changed the tip size I forgot to change the needle . Sat there wondering why it would not spray .:facepalm: :facepalm: :rolleyes:
Trooper82
I look a it as experience...
Trooper82
Turned my head and RACCOONS struck....
Guess it is a Custom boat now...with a custom paint job and all...
jbcurt00
Carp, now you need to put in a plexi floor so their art can be seen & appreciated:D
