Trooper82
Thread starter- Joined
- Nov 21, 2011
- 2,648
If you tools are burning you when you pick them up....
It might be too hot to work...
I got the inside edges sanded with a belt sander....that sucked in this heat, sweating like crazy... but I got it done...
Also got the holes for the screws pre-drilled
Cooling off a bit, then going to countersink the holes...
then see if I can get some 5200 down in the holes...put some PL under the outside edges...
Then screw that puppy down!!
I got some jigs made up to cap the holes I put in for foam. Will lay a sheet of plastic over the hole then put the blocks over holes when pouring the foam. Will have to wait a few day for the PL to cure...I may try to get some PB on it though...then I could do the foam today?
