Been in the process of redoing the boat got to the motor and had to replace water pump, starting solenoid, fuel pump.. Tried starting forever wouldn't fire. Took apart carbs cleaned put back releazied the break away switch was broke. Placed a jumper on wires for testing purposes. Got fire she started. Now it doesn't fire at all just spins starter but never gets any spark. New plugs tested the coil packs nothing going to them tried hooking back to breakaway and still not firing just spinning. Does anyone have any ideas or wire diagram so i can trace wires to see if it's the wires for the breakaway or the ignition switch??
Thank you in advance
