hey guys have a starting/battery question. i just got my boat and tried multiple auto batterys from 550 to 850 cca to start the motor and no matter wat battery i use i can only get about 8 seconds of strong cranking before its too weak the turn the motor fast enough to start. i even tried with the charger on it at bout 35amps and start mode 200amp and the same thing happens. when i put the charge on any battery the mter on the charge stays at about 15-20amps even on the 200amp mode is that how it should be or is my charger not working. what should the gauge on the charge read and what is it showing me? thanks so much guys
