redneck joe
- Joined
- Mar 18, 2009
- 15,553
does the wood go under the splashwell?
What gun did you buy?
How do you remove the solid ones?
I went with a dedicated ATS 4X rivet gun. I've used a standard air hammer in the past and its fine for setting one or two, but well worth picking up an actual rivet gun if you have several solids to drive.What gun did you buy?
I went through a bunch of the cheap Harbor Freight bits, but finally switched to the Dewalt Pilot Point bits like Watermann showed above and never broke one of those.for the prob 40 or so i might drill out, how many bits should I get and are there best in class brands? I'm cheap but i'm not poor and i understand god tools/supplies
think it would bend in the wrong place to get as high as needed, it appears there are blind rivets in the decking i need to get to.For the ones on the sides, could you hook something under the edge and pull them up out of the way? Like a ratchet strap, easier and better looking than cutting them off.
The one behind it, it looks like the too edge of the splashwell is welded to it.
You could still remove the splashwell and leave the transom in. I guess it depends on how thorough you want to get with everything. If the decking is in need, I'd be willing to bet your transom is no longer at 100%. Now would be the time to do it, but it all depends on what your timeline and end goal is.to clarify above post, i was talking about no need to remove the transom.
