kenmyfam
- Joined
- Aug 10, 2006
- 14,395
Re: 84 115 Johnson running problem!!! ARGGG
Now you have to determine if it is the pump or the pulse causing the issue. Would be nice to know what pump you installed though. Do you know anyone with a similar outboard you could try that pump on to see if it is the pump ???
Well looks like you hit the nail on the head with this one. I pulled the out line off the pump, stuck the line into a container, pumped the bulb, yup solid fuel coming out, crank the engine, well, lets just say I can pee harder then it came out of that pump, it had just a slight dribble.
