85 evinrude alarm
timmee73
I have a 1985 evinrude 150. I removed the vro and the wires that went with it. I took it out last weekend and it ran fine ( went about 2 miles fished a bout an hr, ran bout 2 miles fished bout an hr). When I left to go back to the ramp my aerator hose had come off and my bilge was stopped up( lucky day). I had got on plane (b4 realizing i was full of water) and the alarm started going off and the motor was shutting down. I went to the first sand bar plugged the pump off, and emptied out about 2 gal of water. I tried to take off again and the alarm came back on, so I idled back to the ramp. During the week I fixed the pump and bilge, Went out again this weekend and went bout 1mile and the alarm came on again (no water in the boat). Pee hole keeps a steady stream of water. Any suggestions on what to try?
Thanks
petryshyn
Re: 85 evinrude alarm
did you forget to pre-mix? have you serviced the thermostats? does it have full power before alarm?
timmee73
I premixed 50:1 I ahve not done anything with the thermostats and the first time it went off yesterday it was on plane about 3500 rpm after that if I can not get up on plane without the alarm going off
thanks for the help
petryshyn
Don't run it long like this until the problem is rectified.
Sounds like you have a fuel starvation or cooling problem. Either will kill that engine. Borrow a infrared thermometer and check the head temps. This MAY limit your search down to one side.
Pee hole is not a indication of sufficient cooling. Visual inspection of the impeller, or at least a pressure test would give more incite....
timmee73
I removed the plugs when I got back home about 2 hrs after shutting off the engine and they were wet
