85HP Johno Tacho Problem
Hi Guys,
I have an older modle 85hp Johno and am having problems fitting a new tacho. I have a constant 12V supplied to the red and black wire when the ignition is on. there is a purple wire there from an old broken tacho which i thought would be sending the rpm from the motor but when i plug it in and start the motor nothing happens. with the ignition on i measured 4V between the purple wire and the black wire.
Any suggestions on why it wont work?
ezeke
Re: 85HP Johno Tacho Problem
The purple wire is positive voltage from the ignition. The sender wire is grey.
where abouts should the grey wire connect on the motor?
ezeke
If it were a 1982 model, the grey wire would connect at the engine terminal block to the yellow and grey wire from the stator and timer base.
The rectifier would have one of its yellow wires connected to the same terminal or one that is crossed over to it.
Thanks for that!!
Do you know what sort of voltage i should be getting through the grey wire?
F_R
The gray wire carries AC voltage because it isn't rectified yet. And it isn't 60 Hz AC. I doubt the tach really cares how much voltage it is. It is only counting the pulses.
D
DJ
Guest
JamesL,
You have two topics going with the same question. Please do not do that. It is confusing and duplicates effort for those that want to help.
Your other post is below.
where abouts can i find a wiring diagram to wire up a tacho?
Any help would be great
F_R
7 / 2006
post # 997 of 1000
-- Interact -- View Profile Ignore User Posts In This ThreadWhisperPost Options Edit Post PM User Report Post
Back to top
71.101.219.135 Post Subject: Re: 85hp johnson Posted: 4:14pm Today
I have some of them, but need a year or model or something in order to know which one to give you.
WillyBWright
America's Dairyland.
Smell our Dairy Air.
12 / 2003
post # 5805 of 5806
-- Interact -- View Profile Ignore User Posts In This ThreadWhisperVisit Website Post Options Edit Post PM User Report Post
Back to top
75.51.10.31 Post Subject: Re: 85hp johnson Posted: 4:17pm Today
If it's reasonably new,
Black to Neg or Gnd
Purple to Ign
Gray to Sig
Blue to light
You can lead a boat to water, but you can't make it think.
Take a Boating Safety course. Many are online.
They're either cheap or free. (Keywords online boat safe)
JamesL
2 / 2007
post # 4 of 5
Back to top
202.7.176.131 Post Subject: Re: 85hp johnson Posted: 4:21pm Today
Its an older V4 think its about 1980's. what kind of voltages should i be getting from the sender?
