What a mess. This thing starts on the first bump and will run in neutral great. When you put it in gear it will jump out of the hole like crazy and plane out great. It will run for about 40 - 60 seconds then cut out like it is running on two cylinders. You can shut it off and turn it right back on and it will run out great again but cut right back out. Tonight on the lake I touched the throttle position sensor and it shocked me a little is that normal. I also noticed when I was changing it out and putting on a new throttle position sensor it sparked just a tad from the screw to the screw driver. Got to looking and found a ground under the CDI was lose could this be the entire problem. Prior to running today I rebuilt the carbs which were clean, new fuel pump kit, and spark test good. Also it is has a tiller kit on it and all the sensors are removed as well as the oil tank and pump disconnected. I say this because when it cuts out it seems like it is killing a cylinder as if it is going into safe mode. I also checked the plugs after today and all were golden brown and just replaced a few days back. The compression is 120 on all three cylinders. I appreciate any help here.
