On my 87 125hp I can raise and lower the motor but what happens is after raising the motor with the trim tilt switch like when you are taking the boat out of the water the motor slowly goes back down. By the time I get it out of the water like 5 minutes its back to the run position. There are no leaks at the connections so I am thinking its a bad seal in the ram. My question is is there rebuild kits for this cause I have not found any or is it something else.
