88 omc outdrive
payton1803
hi all, new to the boating world. have an 88 bayliner 21' cuddy cabin with a 5.7 and omc outdrive, need to replace engine. cannot get outdrive off, can get it back about an inch or so but cannot get it out. new to the boat world but i have been a gm tecnician for 20+ years, don't know if i am doing something wrong or what, had shifter in neutral but still will not come out
Levinz11
Re: 88 omc outdrive
I usually have more trouble taking mine off than putting it back on. I rock mine back and forth (side to side) and it gradually slides off the studs. You can also use the trim rams to "break" it free.
payton1803
Re: 88 omc outdrive
the outdrive is broken free but won't come out, i have pried it as much as i dare, i put trim cylinders back on and tried pushing it out with that , but it still won't come off, i get it out about 1 1/2 inches but if you take off the pressure it pulls riht back it, motor in boat is siezed so i cant turn motor, at a loss as to what to try next
scott
jerryjerry05
Re: 88 omc outdrive
PRY.
Big pry bar and lift drive.Put bar under the front of the drive and drop it and maybe the drive will work it's way back?
If that won't work??Then inside the boat.Loosen the bellhousing. Then try to get at the coupler bolts/nuts.
Or take it to the shop for a little help.
It sounds like it's stuck on the o-rings on the shaft.?
Idlespeedonly
Re: 88 omc outdrive
Keep in mind the surfaces that you will be prying against are the same surfaces that have to be sealed watertight with a thin gasket. So, if you gouge the surfaces bad enough you will have problems.
payton1803
Re: 88 omc outdrive
finally got drive out tonight shaft was rusted to drive coupling, no grease at all on splines, had to push out with trim cylinders and made wooden shims kept putting in more shims as i could and prying on top. after i got it out found round spring from gimble bearing seal on input shaft so now i guess i will have to change that as well. at least its out , now tomorrow i can pull engine.
