Ok got a 89 30hp e30elced with cdi ignition with controls for throttle and shift at helm. Is the plate supposed to rotate under the flywheel when the throttle is advanced? It does not and this is the first evinrude I have worked on that it does not move. There is just a small rod with a set screw clamp That is connected to a cam connected to throttle cable with the other end connected to a lever that has a small rod connecting to the carb I cant seem to get it running right. Cleaned carb had to replace exciter coil under flywheel due to no spark. Has a hard time idling only way to get it to idle is back out low speed 2.5 to 3 turns or more. Then when I advance the throttle it just Boggs out. If I use the primer at strategic times I can get it to come off idle and run 1/2 to full throttle. New gas also.
