Speedometer did not work today and upon inspection I noticed that the tube was kinked from, I believe, getting caught between motor and swivel bracket. I took it apart and repaired but it seems that the problem will occur again due to the design and positioning of the tube. My fish finder system has a speedo so it's not a big deal if it dosn't work but being anal about the boat make's me ask for suggestions. The tube seems to be very long and loose and has a joint in the middle as if someone lengthned it at one time?. Is their anything I can do to stop this from happening again?. The tube enters a little hole behind the tilt tube and makes it way down behind the swivel bracket but is not protected from crushing.
