89 Force 150 tachometer question.
poor_boy67
Being a newbie to the world of boating, last week I bought an 18' 82 Champion F/S that has an 89 Force 150 on it. I believe the original motor was a 150 Merc. and was replaced due to a blown power head. With the help from my father-n-law we've checked the motor out and done some preventive maintenance such as replaced impeller and compression test which was pretty even across the board between 150 and 152 lbs. Doing preliminary research I found the optimum RPM range to be 5000 to 5500 or 5250 target. With that being said we put this thing out on the water Friday night to see what she would do and it ran out great , engine seemed to have plenty of power ran nice and smooth. My father-n-law open this thing up and we were flat moving across the lake. I looked down at the RPM guage and that thing was reading 8000 rpms, I thought holy crap he is going to blow my motor. Then he backed it off a little bit to where the chrysler control said gas saver and the RPM guage still was reading 7200 rpm the motor was humming nice and smooth with no strain. That leads me to the question do I need to change the tachometer or can it be recalibrated. I can't hardly belive that the motor designed to run 5500 rpm at WOT is running any 8000 rpms and not showing any signs of problems. Thanks for any help.
jerryjerry05
Re: 89 Force 150 tachometer question.
Loose wire?Or on the back of the tach is a dial.It changes with the different motors.It needs to be pushed in to turn.Try that.If that doesn't work I have a tach that will work(cheap).J
poor_boy67
Thanks for your response Jerry, I do not see any dial on the back of this tach. Come to find out the guy I bought his boat from said the previous motor was a 200 Merc. attched is pictures of the tach. how much do you want for tach that will work?
NYBo
If that's the tach used with the Merc, it won't work properly with your Force. You need a tach made specifically for 20-pole alternator output.
Jack Daniels
Yep you probably need a new tach, make sure its a 20 pole. I bought a new one on ebay by stewart warner for 30 bucks and it works like a charm. Good Luck
