Re: 89 Johnson GT150 will not plane boat
It doesn't make sense.
Top cyl isn't getting fuel, you swap carbs and it still doesn't get fuel.?
You might be misreading the signs here. Check it.
Crank engine and spray fuel or WD40 into the dry carb, don't run it.
Now look at that plug, should be wet.
