just-want-to-fish
- Joined
- Jul 11, 2006
- 3
9.5 Evinrude Sportwin - sluggish!
Hello all! I've just accuired a 1970 evinrude sportwin 95hp.. The model is 9022c and the serial is E04143. I got this from a very trusted friend who indicates it only has 1520- hours on it. Judging how the unit looks, I would tend to believe him. He also says it hasnt' been ran in over 15 years! I took the fuel lines off and cleaned them out. Also sprayed some carb cleaner through the top of the carb, changed the plugs (did nothing with the gap) flushed some fresh gas (with SEAFOAMthrough) the lines and tank. Low and behold it started! The problem is this. The unit will run at idle but wants to stall when it is put in gear and some throttle is applied. When it does take off, it will not power up very much. it is on a 12' aluminum boat and will not plane it out. Any help would be greatly appreciated. I would like any recomendations for things I should do to do to keep this baby going!
