9.5hp Evinrude Driveshaft comes out of lower???
CaptainHook
Just a quick question. I am changing the impeller in a 1973 9.5hp evinrude. After pulling the pump housing and impeller the driveshaft now slips in and out of the lower unit.
Is this normal? Do the impeller and housing actually hold the drive shaft in place?
Just wondering before I put this together and have problems.
ezeke
Re: 9.5hp Evinrude Driveshaft comes out of lower???
That's correct; the driveshaft will stay in place once the waterpump is reassembled.
restornator
it also stays in place once the lower unit is mounted on to the exhaust housing
CaptainHook
I know the drive shaft stays in when the lower is mounted. Not like it can go anywhere.
Anyway, thanks ezeke!!! I Was unsure and didn't want to put this back together if there was a retainer or something that needed replacing. I appreciate the help!!
