9.9 johnson has spark on one only
kaiuli1
I,m not sure what year this motor is but it,s a older model. The number I got off the block is J2908486. My problem is spark only on one side, I change the points,condenser and coil around but still no spark on the same side.I checked the plugs and wires too.can anybody help me?
lyncraft_mechanic
Re: 9.9 johnson has spark on one only
there is no power pak if the engine is equipped with points and condensors. is there any other numbers on the engine? look on the transom bracket for a model number. did you replace both coils condensors and point sets? did you set the points to .020? did you replace the plug wires? if so did you use solid core plug wires? if not you could have a bad plug wire!!!!!
kaiuli1
the model # is CD-25R.the plug wires checked out ok and coil, points, condenser and plugs also ok. the plate that these components sit does it come off? theres a key on the shaft anything else? also the spark that comes off that one side is white not blue.
asdasc
CD-25 is a 6HP from 1968, not a 9.9HP as far as I can see in my chart.
White spark is a weak spark. Most likely the adjustment on the coil alignment is off, or the condensor is bad. Check out this thread to see if helps.
How to change points, condensors, coils in old Johnson
lyncraft_mechanic
asdasc
no problem! At least we came up with the same answer...:)
kaiuli1
thanks guys for the info. still working on it. mahalo kaiuli
