9.9 Mercury lower crank shaft bearing removal
James R
I have a bearing puller and have removed the circlip. This bearing seems to need a lot of force. Any thoughts?
latin monkey
Re: 9.9 Mercury lower crank shaft bearing removal
remember the new bearing needs to be pressed on also, take it to a machine shop and they can do upper and lower bearings for you in no time
James R
Thanks for the input LM.
