90 fitting on valve cover
Onexl85
Hello,
recently purchased a 2001 rinker 242 fiesta vee. It has a 5.0 mercruiser EFI. The starboard valve cover has a 90 degree fitting on it going nowhere. Is this normal? My 350 carb had breather tubes going to the carb
Nope,.... There should be some sorta hose from it, to a port on the flame arrester or there abouts,....
Kinda like yer ole 350,.....
later ones have a check valve on one side and only one hose on the other.
Onexl85
Is there any reason the seller would remove this? I can’t see it masking any kind of a problem
Grub54891
It's just missing the hose tat goes to the flame arrester. It'll leave a bit of oil on the motor from blow by if you don't replace it.
