I have a 90 HP Chrysler about a 1976, SN is 7682. Cruising at speed, its is fine, but if I idle it for 5+ minutes its get hot. I already replaced the impeller, and it is pumping, but at idle there is very little water coming out of the ports at the back of the motor.
The impeller that I removed was in fair shape and still had all its vanes attached. But the new impeller is pumping no better at idle then the old one did.
Before reinstalling the lower unit I ran water up the water line with a hose, and did not get much flow, but when I put the hose to the water exit port at the back of the intermediate cover, I had good flow out the water tube. I have a manual ordered, so I will check that when I get it. I suppose there could be a partial blockage in the flow tube up to the engine head.
I found in another thread information about adding a tell tale to the motor, it looks like a great idea, so next time I run it I will be removing the plug at the top of the motor to check water flow from there. If there is a partial blockage from below, I am wondering if adding the tell tale indicator would be a 'cheap fix' for the low idle flow problem.
