90 johnson engine alarm
cisnet
I have a 90 60hp johnson outboard with OMC controls the alarm went off last time I used it and it shut down I let it sit for a bit alarm went off and it started fine it seems to be getting oil and not hot went I took cover off? What cause alarms? never had boat with that before?
tashasdaddy
Re: 90 johnson engine alarm
what alarm?
J/E Alarms
low oil alarm is a beep every 30 seconds. beep......................beep...................
no oil alarm is a beep every 1/2 second or so.beep,beep,beep
overheat and fuel restriction alarm is a constant beep.beeeeeeeeeeeeeeeeeeeeeep
ezeke
Continuous horn = overheat
Continuous short beeps = no oil
Short beeps every 20 to 40 seconds = low oil
Some motors have been set up with vacuum switch for fuel obstruction alarm; that will also sound a continuous horn alarm if so equipped.
cisnet
it was a constant sound much like a fire alarm.... but i shut it down right away took hood off and nothing seemed hot?? But it did fire back up after 15mins or so. I trolled with it for a few hours at 3mph is that too slow for the motor? would that cause it to overheat?
ezeke
It probably shut down from overheating and binding. You should do the following:
1. Check compression,
2. Service your waterpump
3. Service your thermostats
4. Check your sparkplugs for signs of water intrusion.
