I have a 91 Seaswirl with a 4.3 Cobra. I'm changing the shifter Cable from the lever to the engine and to do that I had to put the lever in reverse to access the lever set screw and remove the lever to remove the assembly. Once i put the new cable on, mounted everything back to the panel, and put the lever on in the reverse position so i could tighten the set screw, the shifter cable doesnt move and is stuck in the reverse position. All help is greatly appreciated.
