92 AMK OMC King Cobra P/N Question/Verification
Apathetic
Hi,
I do not have the part numbers for OMC drive unit stuff for 1992, only 1991. I want to order a complete water pump kit for my drive. Is mine the same as 984461 listed in 1991 or different?
Thank you in advance for taking the time to help, my boat information is listed below.
James
Boat:
1992 Four Winns Liberator 201 w/ cone clutch 351 King Cobra
Engine:
Model # 584DPEAMK
Serial # T01242551
Drive:
Model # 987526
Serial # T00756837
Boatin Bob
Re: 92 AMK OMC King Cobra P/N Question/Verification
No they are different in 1992 as the drive went through some serious changes see item # 13 below
Try a local Johnson/Evinrude dealer as they can order parts from BRP
Also try these guys as they list it 1992 Water Pump Kit
Stern Drive
1992
5.80
584DPEAMH 1992
WATER PUMP & ADAPTOR
1 0987214 ADAPTOR SEAL & BEARING
2 0389039 BEARING, Water pump adaptor
3 0910901 INSERT, Adaptor
4 0915702 SEAL, Water pump adaptor
5 0915075 WASHER, Thrust, drive gear
7 0986729 GEAR & SHAFT, Water pump
8 0914013 GEAR, Water pump drive
9 0915022 SHAFT, Water pump Use 984264 stub & water pump shaft ay for cobra. Use 986729 gear & shaft ay for 1990-93 super nova cobra which uses clutch cone drive in upper g'case.
10 0914030 SEAL, Adaptor to gear hsg., inlet
11 0385043 BEARING, Water pump drive gear
12 0908668 SCREW, Adaptor, upper
13 0987253 WATER PUMP REPAIR KIT
14 0915277 GASKET, Plate to adaptor
15 0987176 IMPELLER, Water pump
16 0915219 LINER, Water pump
17 0915216 PLATE, Water pump
18 0915217 SEAL, Water pump to plate
19 0915595 VENT HOSE, Impeller housing
20 0987175 IMPELLER HOUSING
21 0913833 SCREW, Impeller hsg. to adaptor
22 0908511 SCREW, Adaptor
23 0914031 SEAL, Adaptor to gear hsg., outlet
24 0911719 PLUG, Water drain
25 0911311 O-RING, Water drain plug
26 0915068 SCREW, Rear cover
27 0913892 COVER, Gearcase, rear
28 0911686 O-RING, Adaptor to gear housing
Apathetic
Does anyone have a source for that water pump repair kit? I've googled the part number and find nothing, whereas when I googled the (wrong) part number I come up with quite a few hits.
Boatin Bob, thanks for this information. Do you/would you happen to have the part number break down for the above part list? I'd appreciate it very much. I purchased my OMC manual, part list and owners manual from MarineEngine.com but they were out of the 92 part lists so they sent me a 91 instead.
Thanks in advance.
Boatin Bob
See update above for numbers and other source
Freedom
James,
If you go to www.johnson.com (it's easier than the evinrude site) there is a link to "genuine parts" and then a link to "engine diagrams", BRP has all sterndrive engine diagrams online from 1968 to 1998.
There is also a link to "non-current literature" which takes you to kencook.com. They don't list your sterndrive model but it might be worth a call, I got an original OMC service manual for my 1989 2.3L King Cobra this summer from them.
Actually I just did another search on their site using just "584" and got several hits for 1992. They have model 584DPEAM and 584DPEAMH. I know my one service manual covered all models and engines sizes in 1989.
Apathetic
Boatin Bob,
I cannot even begin to thank you enough for this post and even more so for you taking the time to finding the part for me (crossing my fingers that they have it in stock). I wish I could buy you a beer or something. You have been a HUGE help. Like I said, I simply can't thank you enough.
Freedom,
Thank you for your input as well. As we speak I am checking out the site you posted and bookmarking it. Thank you for taking the time to post it. I do have the factory OMC repair manual for my year as well as the OMC factory owners manual for my year. Unfortunately the part list I got was for '91's. I'm going to check out the site you listed to see if I can get those '92 part lists. Thank you again!
I will update this post if the parts were in stock (and once I receive them) so if anybody doing a search needs to find them can.
Thank you both again.
James
Boatin Bob
James...good luck
as for the beer, once I figure out how you can send it through the internet I'll let you know ;)
HT32BSX115
Oh NO, another Liberator!
Hi James,
How fast is your Liberator at WOT?
Neat boat!
Cheers,
Rick
Apathetic
Update for anyone with the cone clutch drive:
I ordered the part last night (10/5/2006) but received an email that it was not in stock. They (Doug Russel Marine) have ordered the part. I'll let you know if it comes in and when it comes in.
Boatin Bob,
If you're ever in Virginia or I am ever in Ontario the beer will be flowing. 8)
HT32BSX115 (Rick),
I love my Liberator. I cannot tell you what my top speed is because I bought the boat very late in the season and never got to enjoy it. The previous owner had it sold at Smith Mountain Yacht on consignment and they said it was between 50 and 55, but I'll believe it when I see it. The boat meets our needs, though, and I just truly love it, enough to where I will re-power it and switch to Volvo-Penta one day.
I know a guy on one of the car sites I visit that just bought an '87 or '88 big block 211 Liberator. It's a sharp boat.
Take care,
James
bruceb58
Another source for parts is Fast Eddies Marine. Google it to get the link.
Apathetic
Thanks bruceb58. I have found them and bookmarked them. I will try and contact them tomorrow and see if they have the part available.
Fast Eddies = http://www.fasteddiesmarineparts.com/ for anyone who may be looking for it.
Thanks again,
James
HT32BSX115
It's a neat boat!
I get about 50 mph (GPS) at 4200 rpm
Hope you get it fixed
I'd love to replace the 460/OMC with a Volvo Penta 425HP EFI package !
Cheers,
Rick
Boatin Bob,
HT32BSX115 (Rick),
Take care,
James
Apathetic
Quick update for anyone that may care or may need the info:
1) Doug Russel Marine got the part in and I received it today.
2) Fast Eddie's Marine Parts had it in stock, too.
Depending on where you purchase it you are looking at $113 to $153 for the part (water pump repair kit).
I want to, again, thank you Boatin Bob and bruceb58 for the leads to finding the part. I cannot thank either of you enough.
I also want to thank you, Freedom, as the BRP site was VERY helpful and is now in my favorite bookmarks.
Lastly, thanks HT32BSX115 (Rick), for the Liberator talk. I hope to be able to answer you with my GPS but I'll have to sit it out until spring I'm afraid.
Thanks again, this site is fantastic and you guys and gals are fantastic.
James
bruceb58
Was Fast Eddies the cheaper of the two places?
Boatin Bob
Looks like Fast Eddies was $40 cheaper since DR was the $153 part...good for you, glad you were able to get it and hope this solves your problem, the $40 you saved can always go to the gas pump!
ooops....just reread the post again looks like you got it from DR and didn't save the $40??
Apathetic
Sorry guys that I was unavailable.
Yes, I had already put an order in it at DRM, so I paid more. Fast Eddies was the cheapest site I found. But, believe me, all that matters is I got the part in. I did the work yesterday and the boat is in "ship shape." Naturally, had I not already ordered I would have paid less ;) but it was worth the extra money to get the part when I did and be back out for a few more weeks until the season is over. I hope this thread will be useful for others, too.
Again, I thank both of you sincerely. If you're ever in the Chesapeake Bay, particularly the Rappahannock River, I'll buy you a beer and a dinner. 8)
Thanks,
James
