mrnmrskyle
Thread starter- Joined
- Apr 8, 2013
- 56
Okay, Well I don't get on this forum a whole lot, but I have found that if you want help with something besides a shiny new 4 stroke it's the best place to go with anything!
i have a 92ish Mariner 150 2.0L on my 21ft Offshore Yacht Center Console. When I first bought the boat it had a defiant issue running (found out bad switch box) but when it did run during the lake test it went about 40mph. The tach did not work. We used the boat all last week down at the beach (5 days in a row) and it ran great, but would never get over 30mph and took a long time to plane.
well I finally had time to look it over yesterday, at idle the batteries were at 14.4 volts (I have 2 on a switch, if i set it to "ALL" it would drop down a little bit") I took the grey tach wire from the top voltage regulator and moved it to the bottom one and the tach started working fine. Would this say bad regulator replace?
would the voltage regulator have any side effects where the engine wouldn't run as hard under load? I pulled plug wires off yesterday and it seemed that they were all firing... did seem like the port side were a little less strong (but I was also listening to it, didn't have an official tester with me)
the stator is new, plugs are new, one switchbox is new... so any ideas? and mainly does no tach signal mean bad regulator?
and my serial number isn't very easily read, the cowling says 2.0 it's carbed, 1 piece cowling, has 2 voltage regulators, if anyone knows around what year model it could be..
