93 Evinrude 60Hp
0438557 is the pump to use.----Remove pulse limiter as it is not needed for that pump.
Flyhog85
thanks for all your help. I’ve slowly been checking off possible causes and am now down to a stuck float or clogged jet in a carb or an intermittent issue with my pump. It’s running a tad rich at times and my fuel economy has absolutely tanked. I do have a lot of debris in my tank so I also plan to remove it and clean it out really good as well before going back together with it all. Trying to get the boat ready for the trout spawn here in Arkansas this fall/winter.
Pump from a 65 HP--- " commercial "----model.----Many years used 438557
flyingscott
You need to put a nipple in where the pulse limiter is. The new pu!p will need to use it.
Put a straight fitting in there.----The pump needs PRESSURE pulses to work.
