martybhawk
Thread starter- Joined
- Apr 17, 2007
- 11
1 month ago Tach stopped working - replaced Regulator/Rectifier and tach works again - noticed Rectifier was dated 2003 so it has now been replaced at least twice - last week, engine started running very rough or completely stopping when I advance throttle - it will crank and run fine at idle or very low RPM's - I replaced fuel line, filter and cleaned out some debris from gas tank - still running rough - took to mechanic - he replaced plugs and cleaned carbs - still running rough - he said stator was burned looking and he was getting 14 volt reading on "something??" - he said powerpack, stator, rectifier were CDI aftermarket so we know they have been replaced at least once - he is checking wiring???
Any ideas on what is causing components to go out?
