jimbobcooter
Thread starter- Joined
- Feb 27, 2012
- 78
Went out yesterday and took a bit to get her started once started I made it about 30ft out of the slip when she stalled. I was able to get her started again and she quickly died again. After a long period of not starting I was able to get her going one last time and I had her at a fast idle for about 30sec before she died again....like she was not getting fuel...Noticed the bulb was not holding prime.
So I started to take apart the fuel line to make sure the engine was getting fuel. Upon trying to remove the main fuel line the inlet to the fuel pump came off /broke?.... There was a gasket under it that had a passage all the way around the edge except for one spot where it was just a hole. It didn'tt really appear to be broken off but when I tried to reinstall and pump the bulb fuel just spilled out around the fitting.
Obviously I have to fix the fuel pump main inlet before I can troubleshoot the main issue. Does the pump inlet simpley snap in? is it glued? should I just replace the outer cover or rebuild the pump?
