bloody knuckles
- Joined
- Aug 4, 2007
- 15
Re: '95 70hp Evinrude needs Viagra...
Ok...a reset. Initial issue was lack of power at WOT. RPMs would max out at 2200-2500 depending on load in boat. Water test of f.pump by squeezing bulb repeatedly. Got hard but didn't improve performance (insert viagra joke here) No SLOW warning alarm but never really trusted it anyway so;
Treated with carb cleaner
Compression tested good for all 3 and good when compared to each other
New plugs, new stat (never changed b4), new water pump (3-4 season)
Checked function of each cyl by pulling plug wire while running (only 1 at a time) #3 had no affect on RPMs when pulled, 1 & 2 did. Swapped wires and plugs to isolate potential issues, same result when plug wires pulled.
Rebuilt carbs believing #3 had an issue and might as well do them all.
Put it all back together and tested with muffs. Idled ok for first 20-30 seconds and then ran away to WOT on it's own. Shut it down asap. Removed linkage and found black plastic spacer or washer piece wasn't put back on the throttle plate to linkage connection, but I don't think that was the issue. After pulling linkage back off tested each carb as discribed above. Not sure what to make of the dieing out of #2 & #3 and the fact that #1 responded as expected.
I just went out there a found a mysterious wire bundle disconnected and tucked between the f.pump and the carbs. Wires appear to connect to the port side of the fuel pump but it's hard to tell until it's removed. Four wires; black, grey, orange and purple. They progress up from the f.pump to a hard plastic connecter on the s.s. of the flywheel. The male end appears to be worn from friction against something...maybe the fly-wheel and that's why I tucked it away. Can't remember why that thing is disconnected...maybe something to do with the VRO that was disconnected a LONG time ago? Wouldn't be surprised if it is supposed to be unplugged and tucked away.
I think I can get all the linkage connections back in their proper place and maybe that will take care of the run away syndrome. But, the f.pump still makes that metal clicking sound that is loud and easily felt.
seriously doubt you screwed anything up.....got the linkages back in place? are the throttle valves parallel, moving together, and ending up horizontal (not beyond) at WOT?
when you advance the throttle, does the CAM hit the ROLLER right on the MARK?
what exactly are your symptoms as of right now?
